Este thread fue creado hace 6506 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
06-Jun-2006, 17:47 | #1 |
Araxxus The Destroyer
Vendo Tarjeta de Video!!!
Que onda, ando vendiendo una nVidia Geforce 6800GT reference... PRODUCT FEATURES The NVIDIA GeForce 6800 GT represents the mid-range of present NVDA offerings sandwiched between the 6800nu and the 6800 Ultra. Features: At A Glance -Graphics Core: 256-bit -Memory Interface: 256-bit -Memory Bandwidth: 35.2 GB/sec. -Fill Rate: 6.4 billion texels/sec. -Vertices per Second: 600 Million -Memory Data Rate: 1100 MHz -Pixels per Clock: (peak) 16 -Textures per Pixel*: 16 -RAMDACs: 400 MHz CineFX 3.0 Shading Architecture Vertec Shaders -Support for Microsoft DirectX 9.0 Vertex Shader 3.0 -Displacement mapping -Geometry instancing -Infinite length vertex programs Pixel Shaders -Support for DirectX 9.0 Pixel Shader 3.0 -Full pixel branching support -Support for Multiple Render Targets (MRTs) -Infinite length pixel programs Next-Generation Texture Engine -Up to 16 textures per rendering pass -Support for 16-bit floating point format and 32-bit floating point format -Support for non-power of two textures -Support for sRGB texture format for gamma textures -DirectX and S3TC texture compression -Full 128-bit studio-quality floating point precision through the entire rendering pipeline with native hardware support for 32bpp, 64bpp, and 128bpp rendering modes 64-Bit Texture Filtering and Blending -Full floating point support throughout entire pipeline -Floating point filtering improves the quality of images in motion -Floating point texturing drives new levels of clarity and image detail -Floating point frame buffer blending gives detail to special effects like motion blur and explosions Intellisample 3.0 Technology -Advanced 16x anisotropic filtering -Blistering-fast antialiasing and compression performance -New rotated-grid antialiasing removes jagged edges for incredible edge quality -Support for advanced lossless compression algorithms for color, texture, and z-data at even higher resolutions and frame rates -Fast z-clear -High-resolution compression technology (HCT) increases performance at higher resolutions through advances in compression technology UltraShadow II Technology -Designed to enhance the performance of shadow-intensive games, like id Software's Doom 3 Advanced Video and Display Functionality -Dedicated on-chip video processor -MPEG video encode and decode -WMV9 decode acceleration -Advanced adaptive de-interlacing -High-quality video scaling and filtering -DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i resolutions -Dual integrated 400 MHz RAMDACs for display resolutions up to and including 2048 × 1536 at 85Hz -Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders -Microsoft® Video Mixing Renderer (VMR) supports multiple video windows with full video quality and features in each window -Full NVIDIA® nView™ multi-display technology capability Advanced Display Functionality -Dual integrated 400MHz RAMDACs for display resolutions up to and including 2048x1536 at 85hz -Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders -Full NVIDIA® nView™ multi-display technology capability Advanced Engineering -Designed for PCI Express x16 -Support for AGP 8X including Fast Writes and sideband addressing -Designed for high-speed GDDR3 memory -Advanced thermal management and thermal monitoring NVIDIA® Digital Vibrance Control™ (DVC) 3.0 -DVC color controls -DVC image sharpening controls Operating Systems -Windows XP -Windows ME -Windows 2000 -Windows 9X -Macintosh OS, including OS X -Linux API Support -Complete DirectX support, including the latest version of Microsoft DirectX 9.0 Shader Model 3.0 -Full OpenGL support, including OpenGL 1.5 Features (From Nvidia) NVIDIA® CineFX™ 3.0 Technology Powers the next generation of cinematic realism. Full support for Microsoft® DirectX® 9.0 Shader Model 3.0 enables stunning and complex special effects. Next-generation shader architecture delivers faster and smoother gameplay. NVIDIA® UltraShadow™ II Technology Enhances the performance of bleeding-edge games, like id Software's Doom III, that feature complex scenes with multiple light sources and objects. Second-generation technology delivers more than 4× the shadow processing power over the previous generation. Superscalar 16-pipe GPU Architecture Delivers 8× the shading power of previous generation products for screaming gaming performance. 64-Bit Texture Filtering and Blending Based on the OpenEXR technology from Industrial Light & Magic, NVIDIA’s 64-bit texture implementation sets new standards for image clarity and quality through floating point capabilities in shading, filtering, texturing, and blending. With that idea hopefully implanted in your head, I will be today reviewing Nvidia's reference GEFORCE 6800GT videocard with the goal of supplying the end user with a snap shot of just how well this videocard performs and what they could expect if they picked this card up as their next upgrade. I unfortunately will not be comparing this card to the X800 pro directly seeing I do not have a PCI Express version of that card in hand at the moment. This will definitely change as times roll by and I will update the review (nudge,nudge ATI) when and if the samples arrive. In part, this can be regarded as somewhat as a good thing which allow me to review this card as it stands without getting into the old "this card is 0.5% better than the competitors" reviewing routine. El Precio es de Q. 2000.00 Completamente Negociables, para mas informacion mandar PM... . |
06-Jun-2006, 19:04 | #2 |
OC Addict
Mazda B2500TD
Tiempo: Pela la verga
y ya tenes la otra targeta ahi pue vos.
06-Jun-2006, 19:42 | #3 |
Bump!!!
06-Jun-2006, 19:55 | #4 |
ಠ_ಠ
190E, Galant, 460, e21
Tiempo: 9.90
Nvidia
06-Jun-2006, 21:09 | #5 | |
The Member
07-Jun-2006, 14:51 | #6 |
Bump!!!
12-Jun-2006, 14:49 | #7 |
Wen pue Remato la tarjeta en Q. 1800.00!!!!!!!!!!
Bump!!!!!!!!!!!!!!!! |
15-Jun-2006, 13:29 | #8 |
Bump!!!
Ofrescan...no puedo creer que nadie le guste invertir en cosas wenas!!! Pilas!!! Oferta Unica en su tipo!!! |
16-Jun-2006, 14:16 | #9 |
Bump!!!
16-Jun-2006, 16:16 | #10 |
cervecero chapin
Feedback Score: 41 reviews
si me sale un mi negocio la otra semana armo mi compu nueva y te compro la tarjeta
17-Jun-2006, 08:02 | #11 |
JL AutoPartner
Mustang 68 / 240sx S13
Feedback Score: 65 reviews
vos, ando armandole una compu pa mi hermano.. me quedaria deahuevo la tarjeta pa el, Q1500 te doy
17-Jun-2006, 17:02 | #12 |
1500 muy poco chato...lo menos es 1800...
17-Jun-2006, 18:18 | #13 | |
17-Jun-2006, 18:20 | #14 | |
Sebastian Burreb
17-Jun-2006, 18:24 | #15 | |
ಠ_ಠ
Tiempo: 9.90
PD: |
17-Jun-2006, 18:26 | #16 |
Bump!!!
17-Jun-2006, 19:22 | #17 |
JL AutoPartner
Mula el pisado... shute de verga...
fue una simple oferta |
17-Jun-2006, 20:37 | #18 | |
no querra sacar nuevamente el costo original o si? .... |
18-Jun-2006, 10:14 | #19 | |
si no les interesa no posteen... Bump!!! |
18-Jun-2006, 18:22 | #20 | |
cervecero chapin
18-Jun-2006, 18:49 | #21 |
oka...te voy a mandar pm con mi numero de cel asi me llamas para confirmarme...
= Bump!!! |
19-Jun-2006, 09:11 | #22 |
Bump!!!
19-Jun-2006, 13:14 | #23 |
Feedback Score: 117 reviews
vos
vos no me aceptas algo de lo que estoy vendiendo
o te doy un mother 865 glc y un procesador de 2.4 el mobo tiene 2 meses de uso y 10 de garantia el intcomex |
20-Jun-2006, 11:49 | #24 |
Bump!!!
20-Jun-2006, 15:30 | #25 |
Bump!!!
