Forged fJCW R56
Tiempo: 13's @ 1/4
Feedback Score: 152 reviews
![]() Articulo: Mouse, ratón
-------------------------------------------------------------------------| Modelo/Marca: Mamba / Razer -------------------------------------------------------------------------| Especificaciones: Gaming Grade Wireless Technology Unrivalled gaming grade wireless technology means the Razer Mamba performs as well cordless as it does corded, giving you utter freedom of motion whilst you win gloriously in games. With a 1ms response rate, your command gets executed first even if you and your opponent react at the same time. 4G Dual Sensor System Experience a new standard of gaming precision with the 6400dpi 4G Dual Sensor System, outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional pinpoint tracking. The Razer Mamba can not only match the speed of your swipes, but also allows configuration of cutoff distance to manage liftoff tracking, empowering you with more control than ever, no matter the play style. Improved Battery Life and Charging Dock The Razer Mamba has 15% more battery life than its predecessor, letting you game unwired for longer. When you need to recharge, just pop it on the sleek charging dock which also acts as the wireless receiver unit. Gaming Grade Wireless Technology 6400dpi 4G Dual Sensor System Dual mode wired /wireless functionality 1000Hz Ultrapolling /1ms response time Multi-Color Lighting Up to 200 inches per second* /50g acceleration Approximate size: 128mm x 70mm x 42.5mm Battery Life: Approx 16 hrs (continuous gaming) http://store.razerzone.com/store/raz...oryId.35210600 -------------------------------------------------------------------------| Negocio: Venta -------------------------------------------------------------------------| Tiempo de uso: 4 meses -------------------------------------------------------------------------| Precio: Q1,100! negociables, envien por PM su oferta. -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: Puntual y efectivo. No chivas. -------------------------------------------------------------------------| Estado general: 3pts: BUENO, bueno significa, que esta usado, pero funciona perfectamente, podria tener algunos rayones, le falta caja original y/o accesorios. Trae todos sus accesorios originales, caja, manuales, dock, cable usb, batería y sticker. -------------------------------------------------------------------------| Telefono o Contacto con el Vendedor: Aquí, por PM o al 4041-5248 -------------------------------------------------------------------------- Fotos ![]() ![]() ![]() Articulo: Teclado -------------------------------------------------------------------------| Modelo/Marca: G19 / Logitech -------------------------------------------------------------------------| Especificaciones: Pantalla LCD GamePanel™ inclinable en color Durante el juego y fuera del juego, la pantalla (320 x 240) muestra información relevante como estadísticas de juego, datos de comunicación VOIP, reproducción de vídeo, presentaciones de imágenes y mucho más. Con GamePanel sabrá más. Averigüe por qué es importante. Color de retroiluminación personalizable Puede personalizar la retroiluminación de caracteres para que esté más a tono con el ordenador y otros dispositivos de juego, y para ver mejor las teclas, incluso en la oscuridad. Doce teclas G programables Hay tres macros por tecla, para configurar hasta 36 funciones exclusivas por juego, incluidas acciones de una sola pulsación o macros complejas. También puede crear macros sobre la marcha.* Dos puertos USB 2.0 de alta velocidad Los puertos USB con alimentación permiten transferencias de datos entre periféricos (por ejemplo, reproductores de MP3 y llaves de memoria) a la vez que cargan dispositivos a pilas. Uso simultáneo de teclas Puede usar simultáneamente hasta cinco teclas, para realizar diversas acciones complejas. Modo de juego/escritorio Para evitar interrupciones involuntarias, puede desactivar las teclas de Windows/menú contextual durante el juego. Sistema de distribución de cables inteligente Las ranuras en la parte inferior del teclado dan cabida a los cables del ratón y de los auriculares, entre otros. Acceso multimedia al instante Prácticos controles de una sola pulsación para facilitar el ajuste de volumen y la reproducción de material multimedia. Kit de desarrollo de software (SDK) público Puede cargar las últimas mejoras exclusivas de GamePanel™ creadas por la comunidad de código fuente abierto de Logitech. Memoria integrada Descripción de memoria integrada: Permite guardar perfiles para llevar las preferencias personales a cualquier parte. http://www.logitech.com/es-es/keyboa...#section=specs -------------------------------------------------------------------------| Negocio: Venta -------------------------------------------------------------------------| Tiempo de uso: 4 meses -------------------------------------------------------------------------| Precio: Q1,200 negociables, envien por PM su oferta. -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: Puntual y efectivo. No chivas. -------------------------------------------------------------------------| Estado general: 4pts: COMO NUEVO, como nuevo significa, poco uso, puede faltarle su caja y manuales, pero debe tener accesorios y no rayones. Trae todos sus accesorios originales, caja, manuales, cds y cable de corriente. -------------------------------------------------------------------------| Telefono o Contacto con el Vendedor: Aquí, por PM o al 4041-5248 -------------------------------------------------------------------------- Fotos ![]() ![]() ![]()
N3l50n
Feedback Score: 64 reviews
Respuesta: Mouse Razer Mamba - Teclado Logitech G19
Que buuenOs productos manoo! suerte...recomendadoo.... cuanto lo menos x cada chiiva!! asi lo menos??
Forged fJCW R56
Tiempo: 13's @ 1/4
#4 |
Eunos roadster 91
Feedback Score: 66 reviews
ala que buenisimas chivas espero conseguir dinero
#5 |
The Player
Tiempo: ??
Feedback Score: 72 reviews
por la vida de las putas !!!! que buen precio mano !! a la verga !!! y sin pisto
#6 |
asñldjfañlskgf
EX
![]() ñalskjfñalsjdñflakjsñldkfja suerte mano
#7 |
User C4d and After Effect
Nissan 87
Feedback Score: 147 reviews
Que belleza de mouse y teclado
![]() lastima no tener billic ![]() suerte manin ![]() |
#8 | ||
Forged fJCW R56
Tiempo: 13's @ 1/4
#9 |
Computadoras High End....
El que haya entrado de US
Tiempo: 1/8 10.82 SGT
Feedback Score: 168 reviews
Re: Mouse Razer Mamba - Teclado Logitech G19
por los 2 puedo decir que son una maravilla de articulos.
Lujo de tienda...... INTELAF: Y me dijo una su gran paja (Leedlo con voz de mongol) "Fijese que es normal en estas fuentes de gama alta. por que mire es 80 plus por lo que tienen transformadores muy potentes que manejan y por la potencia hace ruido" ![]() ![]() |
#10 |
Volkswagen Jetta GLI 2004
Estamos confirmados para mañana!!!
#11 |
LS1 :califa:
Tiempo: 9.22
esos mamba son la mera verga vos, uno de los mejores mouse que he tenido y el g19 pues es un buen teclado lo que me gusta es que es maciso y las teclas no se aflojan como las de los razer
Race Your Car NOT Your Mouth ![]() |
#12 | |
Forged fJCW R56
Tiempo: 13's @ 1/4
Ya no me llamaste?
![]() ![]() ![]() Cita:
g19, gaming, logitech, mamba, razer |
