Subastas Sección para todas las subastas de venta de artículos de cualquier tipo (¡Gratis!) |
Este thread fue creado hace 2492 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
01-Aug-2017, 11:57 | #1 |
Gamer 4ever
Feedback Score: 174 reviews
♦♦♦♦♦♦♦HDMI Switch KINIVO, conecte 5 HDMI's en 1 TV♦♦♦♦Termina 2 de agosto♦8PM♦♦♦♦♦♦♦
Articulo: KINIVO HDMI Switch.
-------------------------------------------------------------------------| Modelo/Marca: KINIVO HDMI Switch 501BN -------------------------------------------------------------------------| Especificaciones: Kinivo 501BN is a premium quality High speed HDMI Switch for your gaming or home theater setup. It allows for switching upto 5 HDMI inputs into one output and supports resolutions up to 1080p. Easy plug & play operation Simply plug in the hdmi input sources into the input connections and the output connection to your TV or projector. 501BN will automatically switch to the currently active input source if there is only one active input. If there are multiple active inputs, then you can select the input either using the IR remote or using the select button on the switch. The HDMI signal from the selected input is passed through to the output HDMI connection. Quality Picture and Sound - Automating switching(smart function), IR remote controlled switching or manual switching - Supports 3D, HDCP 1.2 compliant; Deep color up to 36-bit - Guaranteed 1080p, 1080i, 720p, 480p, and 480i Resolutions - Works with all HDTVs, Blu-ray players, Xbox 360, PS3, Apple TV (all versions) and other HDMI devices - Helps reduce clutter of HDMI wires being fed into your HDTV Note: Apple TV keeps its HDMI port active even in the sleep state. Hence, auto-switching may not work with the Apple TV. Manual switching can still be used in this scenario. Para los que les cueste el ingles ajfoiajfoafaf, es un switch HDMI, excelente para tvs con uno o dos HDMI's, conectan un HDMI al Switch y a la tv, luego conectan ya sea Ps3, Ps4, WiiU, Xbox, Blueray, etc. Pueden conectar hasta 5 aparatos al Switch, y con el control poder cambiar de uno a otro, asi que pueden tener 5 aparatos conectados a su tv . -------------------------------------------------------------------------| Negocio: Subasta -------------------------------------------------------------------------| Tiempo de uso: 8 Meses. -------------------------------------------------------------------------| Tiempo ofrecido de Garantia: 1 semana, unicamente por fallos de fabrica, si ustedes lo moja, botan, etc. NO . -------------------------------------------------------------------------| Lugar de entrega y formas de pago aceptadas: Nos ponemos de acuerdo con el ganador, si es del interior se puede usar Guatex, Cargo expreso o GeoXpress, el ganador paga los gastos de los mismos . -------------------------------------------------------------------------| El vendedor acepta usar el servicio de transacciones de GeoXpress: SI -------------------------------------------------------------------------| Duración/Finalización de subasta: Inicia hoy 01 de Agosto y Finaliza el 02 de Agosto del 2017 a las 8:00 pm. -------------------------------------------------------------------------| Precio de Inicio: Q250 Pujas de: y sus multiplos Q25 y sus multiplos. -------------------------------------------------------------------------| Estado general especificar en base a lo detallado a continuacion: 4pts: COMO NUEVO, como nuevo significa, poco uso, puede faltarle su caja y manuales, pero debe tener accesorios y no rayones. -------------------------------------------------------------------------| Si el articulo es 4pts o menos DEBE ESPECIFICAR DETALLADAMENTE EL ESTADO del articulo: No tengo la caja, saber que la hice, es lo unico que le falta, esta en excelente estado, con su cable de energia y su control . -------------------------------------------------------------------------| Teléfono o Contacto con el Vendedor: Por pm o whatsapp 5595-6002 --------------------------------------------------------------------------| Fotos: Video: |
02-Aug-2017, 09:46 | #2 |
Gamer 4ever
Respuesta: ♦♦♦♦♦♦♦HDMI Switch KINIVO, conecte 5 HDMI's en 1 TV♦♦♦♦Termina 2 de agosto
02-Aug-2017, 14:49 | #3 |
Feedback Score: 84 reviews
voy con la bendicion!!!
02-Aug-2017, 15:27 | #4 |
Gamer 4ever
02-Aug-2017, 18:51 | #5 |
Gamer 4ever
A una hora de que termine |
02-Aug-2017, 20:02 | #6 |
02-Aug-2017, 20:02 | #7 |
Gamer 4ever
