Noticias / Articulos Interesantes Notiicias y articulos interesantes relacionados con el automovilismo presentados en la página principal. |
Este thread fue creado hace 5860 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
25-Apr-2008, 15:31 | #1 |
wtf
Audi A4
Official - Corvette ZR1 Certified at 638 Horsepower and 604 Ft-lbs of Torque
CHEVROLET ANNOUCES CERTIFIED POWER RATINGS FOR THE NEW CHEVROLET CORVETTE ZR1: 638 HP FROM THE SUPERCHARGED LS9 V-8
PONTIAC, Mich. – When it was introduced at the North American International Auto Show in Detroit earlier this year, the 2009 Chevrolet Corvette ZR1's power was estimated at 100 horsepower for each of its 6.2 liters of displacement. GM Powertrain has completed SAE certification of the ZR1's supercharged LS9 V-8 and the results exceed the estimate: 638 horsepower (476 kW) and 604 lb.-ft. of torque (819 Nm). The LS9's output is nearly 103 horses per liter, or just about 1.7 horses for each of the engine's 376 cubic inches. It is unquestionably the most powerful automotive production engine ever manufactured by General Motors and enables the Corvette ZR1 to achieve a top speed of more than 200 mph (322 km/h). "One of the most amazing things about the Corvette ZR1 is the level of refinement that our designers and engineers have attained. Even with all that power, this car has road manners that will allow our customers to enjoy it on the streets as a daily driver, and on the track," said Chevrolet General Manager Ed Peper. The Corvette ZR1 goes on sale this summer. Its 638-hp supercharged engine is complemented in the chassis by heavy-duty components not offered in any other model, including a six-speed manual transmission with race-hardened gears and dual-disc clutch technology that delivers exceptional clamping power and lower inertia, as well as strengthened axle components. Fuel economy testing has not been completed, but engineers are confident the ZR1 will be the most fuel-efficient 600-plus-horsepower car on the market. The LS9 engine is hand-built by specially trained technicians at GM's Performance Build Center in Wixom, Mich. It is a unique, small-volume engine production facility that also builds the Chevrolet Corvette Z06's LS7 engine and other high-performance GM production engines. "Developing the LS9 involved more than simply striving for a great horsepower number. Endurance and reliability testing have shown the engine to be robust and low-maintenance, just like other engines in the small-block family," said Sam Winegarden, executive director, engine engineering for GM Powertrain. "That it is distinguished as the most powerful engine ever from General Motors is a source of immense pride among everyone involved with the LS9." Supercharged aspiration The key enabler of the LS9's performance is the industry's first production application of a new, positive-displacement Roots-type supercharger that has a unique four-lobe rotor design. Its design promotes quieter and more efficient performance, while the large, 2.3-liter displacement ensures adequate air volume at high rpm. Maximum boost pressure is 10.5 psi (0.72 bar). It is teamed with an integrated charge cooling system that reduces inlet air temperature for maximum performance. "The combination of large displacement and the new, four-rotor design broadens the effective range of the supercharger, allowing the engine to make more power at lower rpm and sustain it throughout the power band," said Winegarden. "The low-end torque is tremendous and the high-rpm charge from the supercharger is simply amazing." A raised hood provides adequate clearance for the LS9, while a polycarbonate window in the hood provides a view of the engine beneath it. LS9 details The LS9 features many unique design and manufacturing details that support its high-performance nature. They include: Aluminum cylinder block with iron cylinder liners that are finish-bored and honed with a deck plate installed Forged steel crankshaft with a nine-bolt flange Titanium connecting rods and forged aluminum pistons Stronger, rotocast cylinder heads with 2.16-inch (55 mm) titanium intake valves and 1.59-inch (40.4 mm) hollow-stem, sodium-filled exhaust valves Camshaft with 0.555-inch (14.1 mm) lift for excellent idle and low-speed driving qualities A dry-sump oiling system with 10.5-quart (9.9 liters) capacity Integrated oil cooler and piston-cooling oil squirters Specifications LS9 6.2L SUPERCHARGED V-8 Displacement (cu in / cc): 376 / 6162 Bore & stroke (in / mm): 4.06 x 3.62 / 103.25 x 92 Block material: cast aluminum Cylinder head material: A356-T6 rotocast aluminum Valvetrain: overhead valve, 2 valves per cylinder Fuel delivery: SFI (sequential fuel injection) Compression ratio: 9.1:1 Horsepower / kW: 638 / 476 @ 6500 rpm Torque (lb-ft / Nm): 604 / 819 @ 3800 rpm Fuel shut-off (rpm): 6600 Recommended fuel: premium required Exhaust manifolds: stainless steel Main bearing caps: forged steel Crankshaft: forged steel Camshaft:n hollow steel; 0.555-in (14.1 mm) lift Connecting rods: forged titanium Valves: intake: titanium exhaust: hollow steel Valve lifters: hydraulic roller Supercharger: R2300, four-lobe "Roots" type (2.3L) Additional features: piston oil-spray cooling; direct-mount ignition coils; 11-rib accessory drive |
25-Apr-2008, 15:57 | #2 |
Du Et
qeu funky se mira esa mierda parece una broca de drill... p.d. que nave, hoy si esos cerotes se pasaron...
25-Apr-2008, 16:40 | #3 |
Elektropimp
Con ese torque hay que cambiar llantas a diario jaja
Salu2
25-Apr-2008, 16:45 | #4 |
oO
GTI MKI
Tiempo: slow
25-Apr-2008, 17:03 | #5 |
...Never Say Goodbye...
ala q joya!! q cabrones
25-Apr-2008, 18:31 | #6 |
V6-24
quiero verlo en pista
Boy, life is a never last learning process... |
25-Apr-2008, 20:53 | #7 |
En la U
Geo Tracker y Camaro Z28
Tiempo: No se todavia
grandiosa puta
25-Apr-2008, 21:07 | #8 |
EdPhotography
1995 ep82
se pelaron
. . . el gt
25-Apr-2008, 21:12 | #9 |
Elektropimp
Alguien se anima a armarlo?
Salu2 |
26-Apr-2008, 09:01 | #10 |
-- GT --
SN95 GT 94
Tiempo: Saaaber!!!
Lo talega de esos motorcitos es que le hagan lo que le hagan.. para ellos es suficiente sus dos valvulas por cilindro...
26-Apr-2008, 10:06 | #11 |
Midori Green Pearl
Civic EJ6
Tiempo: mmm..:asaber:
Santo dios ....
Vette tenia que ser
26-Apr-2008, 13:38 | #12 |
Got hids?
Tiempo: 1:43.28-9.62
Feedback Score: 57 reviews
26-Apr-2008, 20:30 | #13 |
Walk!
Golf SR MkIV / GTI MkIII
Tiempo: 1:41:057 APC
La Podadora! VW for life!
27-Apr-2008, 15:38 | #14 |
Pocket Rocket
x miiiiiil
que nivel de motor , se pelaron los de GM |
27-Apr-2008, 20:03 | #15 |
Sin Member
Tiempo: 2005 ja ja
Grandiosima
28-Apr-2008, 20:31 | #16 |
En la U
28-Apr-2008, 20:34 | #17 |
Sin Member
Tiempo: 2005 ja ja
28-Apr-2008, 21:21 | #18 |
WOLVERINE
PONTIAC FIREBIRD 68
Tiempo: WAIT
motorcitos, si pues, y no son necesarias mas de 2 valvulas saca el area cuadrada de 4 valvulas mas pequeñas, 2 valvulas grandes funcionan igual o a veces mejor
Its coming, do it the american way Muscle Everywhere |
29-Apr-2008, 21:24 | #19 |
Club Volkswagen GT
VW Saveiro
Tiempo: 12.21 y 17.76
30-Apr-2008, 09:24 | #20 |
entusiasta Vw air cooled
330ci, 1302s, 1303s.
soy mas domestiquero old school, pero el corvette no hay uno que no me guste increible
09-May-2008, 02:14 | #21 |
GF8 & TA22
Tiempo: 8.93
q mole
09-May-2008, 08:25 | #22 |
Street Racer
Un par de Pasolas Honda
Tiempo: como 3 horas
Ya me imangino ke tiempo hara en pista?????
10-May-2008, 20:02 | #23 |
Gamer
esa nave si lo deja viendo lucesitas a uno...
