Celulares / Accesorios Venta de Celulares y accesorios para celulares (3 créditos) |
Das Auto
Feedback Score: 567 reviews
![]() Articulo: Teléfono celular
-------------------------------------------------------------------------| Modelo/Marca: LG G2 32GB VS980 -------------------------------------------------------------------------| Especificaciones: Chipset Qualcomm MSM8974 Snapdragon 800 CPU Quad-core 2.26 GHz Krait 400 GPU Adreno 330 Espacio interno 32GB A 13-megapixel Optical Image Stabilization (OIS) camera that helps reduce blur in photos and videos when capturing images in motion and improves clarity in extremely low-light conditions. Slide Aside multi-tasking allows three full screen apps or “slides” to run at the same time. QSlide 2.0 maximizes on-screen multi-tasking with the simultaneous use of multiple apps in floating windows, similar to a PC, that can be re-sized and have their level of transparency adjusted. Clip Tray allows you to copy multiple items and paste them in a pop-up clipboard, which can be saved or shared. QuickRemote 2.0 turns your phone into a universal remote for most remote controlled consumer electronics. VoiceMate lets you use your voice to send text messages and emails, and perform other administrative tasks. KnockON lets you wake the display just by knocking twice on the phone’s screen. Más info: http://www.gsmarena.com/lg_g2-5543.php Incluyen
Liberado (si no se puede explique porque): Sí, liberado para todas las empresas. Plan de datos funcionan con las 3 empresas. Señal 3G/4G con las tres empresas. -------------------------------------------------------------------------| Negocio: Venta -------------------------------------------------------------------------| Tiempo de uso: 4 meses -------------------------------------------------------------------------| Precio: VENDIDOS!! -------------------------------------------------------------------------| Tiempo de entrega y forma de pago:
Estado general:3pts: BUENO, bueno significa, que esta usado, pero funciona perfectamente, podria tener algunos rayones, le falta caja original y/o accesorios.
Telefono o Contacto con el Vendedor: Aquí, por PM o al 5238-6376 -------------------------------------------------------------------------| Fotos NEGRO ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() BLANCO - VENDIDO!! [IMG]http://s1.postimg.org/un89tdwrj/20150812_154341.jpg [IMG]http://s1.postimg.org/qfdhkmvbz/20150812_154407.jpg [IMG]http://s1.postimg.org/wqip11wkf/20150812_154413.jpg [IMG]http://s1.postimg.org/8iy3wi8m7/20150812_154420.jpg [IMG]http://s1.postimg.org/ukoe6jt3z/20150812_154424.jpg [IMG]http://s1.postimg.org/c3tzfqd5r/20150812_154429.jpg [IMG]http://s1.postimg.org/699zlqzof/20150812_154433.jpg [IMG]http://s1.postimg.org/6ajxf61i7/20150812_154436.jpg [IMG]http://s1.postimg.org/6btv8l3bz/20150812_154439.jpg [IMG]http://s1.postimg.org/3vs1uql9b/20150812_154448.jpg
✈ Última edición por Dbs; 18-Aug-2015 a las 08:13 |
Das Auto
Respuesta: LG G2 32GB BLANCO Y NEGRO! Como nuevo + acces originales! Liberados, 3G/4G
Das Auto
#4 |
BRN
En el título dice "Como nuevo" y ni le pusiste los 4pts, y mucho menos parece tener ese estado.
apple, galaxy, huawei, note, samsung |
