Varios Compra y Venta de artículos varios... (3 créditos) |
Este thread fue creado hace 6511 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
14-Jan-2007, 23:24 | #1 |
Vendo Bicicleta Jamis Hardtail cc 2.0 NUEVA
Vendo una bicicleta NUEVA
Jamis Cross Country 2.0 Q 4,000.00 PM / msn/ [email protected] FRAME 6061 triple gauge aluminum main tubes and S-bend stays, gussetted down tube, replaceable derailleur hanger FORK RST Omega T7, coil/MCU, magnesium legs, external preload adjustor, 80mm travel HEADSET Tange TG-4 threadless, 1 1/8" WHEELSET Weinmann ZAC19 double wall/eyeletted rims, 32H, with Formula alloy disc hubs, sealed with QR, 14g stainless steel spokes TIRES CST Racing knobbie, 26" x 1.95", wire bead DERAILLEURS Shimano Acera rear, SR XCN-202 31.8mm top pull front SHIFTERS Shimano Acera ST-EF50 EZ-Fire Plus, 24-speed CHAIN KMC HG40 FREEWHEEL Shimano HG-40, 8-speed, 11-32 CRANKSET Shimano M341, 42/32/22, 170mm (12-15.5"), 175mm (17-21") BOTTOM BRACKET Sealed cartridge, TH-7420, 68 x 113 PEDALS ATB platform, hi-impact resin cage & body, with toe clips BRAKESET Tektro IO cable-actuated disc brakes, 6" wavy rotors, with Shimano Acera levers HANDLEBAR Jamis riser, 6D sweep x 13mm rise x 620mm wide STEM Jamis alloy threadless, 10D rise, 75mm (12"), 90mm (14-15.5"), 100mm (17"), and 120mm (19-21") extensions GRIPS Kraton for trigger-shift SEATPOST Jamis alloy micro-adjust, 27.2 x 300mm, with alloy QR clamp SADDLE Jamis ATB with SL top, memory foam, steel rails, front and rear guards SIZES 12", 14", 15.5",17", 19", 21" COLORS Ano Black, Sunset Red WEIGHT 32.25 lbs |
15-Jan-2007, 20:38 | #2 |
Nadie?
