#201 |
Honda Civic / Honda CR-V
Re: Ya esta disponible iOS4 :latigo:
Ando buscando como hacerle un downgrade a esta mierda
![]() Desde que le instale el iOS4 el puto telefono se ha vuelto leeeeeeennnnto, a veces cuesta un vergo hacer una puta llamada, fuck, fuck, fuck, fuck!!!
#202 |
toyota
Feedback Score: 255 reviews
Respuesta: Ya esta disponible iOS4 :latigo:
#203 |
GuAt
Mercedes Benz '74
Mira entonces proba elegir tu perfil, y luego en lugar de install profile, dale a que te lo envien por mail, y asi cuando recibis el mail talvez desde ahi te deja instalarlo, proba eso.
AMD FX-8150 @ 4.5 Ghz Cooler Master Hyper 212 EVO 55c corriendo Prime95 Gigabyte GA-970A-UD3 Corsair 8GB DDR3-1600 RAM XFX Core Edition Crossfired Radeon HD 7770s @ 1200Ghz 2x 1.5 TB Seagate HDD |
#204 |
@El_Patatush
Tiempo: soleado :si:
Feedback Score: 317 reviews
fijate que vi esa opcion ayer y el resultado fue el mismo.. a ver dejame probar una vez mas y te cuento
NO SE PERMITE PUBLICIDAD EN LAS FIRMAS |
#205 | |
GuAt
Mercedes Benz '74
Production version of the webstie has been updated to enable it to email the profiles now. If you get an error when installing via Create Profile you will have to use the Email Profile Option. This error is caused by the jailbreak/unlocking software which people use not via the iOS software itself. Update: All the reports I’ve had have been from Jailbroken iPhones (and all except 1 on iPhones 3G’s) . The profiles install perfectly if they are sent via email to the iPhone and done via the email client. I will have that option set up alter today so until then make sure you have your iPhone’s email set up. I’ve had chance to get an iiPhone which has the above error. If you are getting this error please let me know if its a 3G or a 3GS iPhone and if it has been jailbroken or not. The one I have is a 3G and is jailbroken and another person had 2 iPhones (3GS or a 3G) and the problem only occured on the 3G (jailbroken unknow) I’ve found a work around to it on the iPhone I have but please let me know if its the 3G iPhones which have been jailbroken only? |
#206 | |
@El_Patatush
funcionooooo!!!!!! ![]() ![]() edit: ya averigue, ahi te mande tus dos creditos, buenisima onda por la ayuda, ya funciona la cochinada esa jfkdlasjflañ |
#207 |
Bueno, yo instalé el iOS 4 en el iPhone 3G, al hacerle el jailbreak seleccioné que le activara el Home Screen Wallpaper, el Battery Percentage y el MultiTask.
Como le ha pasado a casi todos los usuarios del iPhone 3G, se puso muy lento, incluso el springboard se crasheaba a cada rato ![]() ![]() Solución para los que tenemos iPhone 3G: vuelvan a realizar el jailbreak, sólo que esta vez dejen el MultiTask, el Battery Percentage pero no dejen que les active el Home Screen Wallpaper. Cuando tengan el iPhone 3G con el jailbreak hecho accesen a el vía SSH (para Mac hay un programa gratuito que se llama Phone Disk, está también CyberDuck, etc) y vayan a esta ruta /System/Library/CoreServices y allí buscan Springboard.app, le dan click derecho y "Show Package Contents" o "Mostrar Contenidos de Paquete" en español, y borran los siguientes archivos:
Con esto eliminan las sombras de los iconos que casi ni se ven, y con fondo obscuro, ni se ven, pero consumen memoria que vuelve más lento el iPhone 3G. ![]() Esto es para un iPhone 3G, con el 3GS no debería de haber problema porque todas las funciones vienen activadas con el iOS 4 sin necesidad de Jailbreak. Esto lo hice yo muchá, y me funcionó, quedó igual o más rápido que con el OS 3.1.2, el MultiTask funciona de manera fluida y los folders igual. Espero que les sirva esta información muchá ![]() Fuente: http://www.actualidadiphone.com/2010...lera-tu-ios-4/ |
#208 |
GuAt
Mercedes Benz '74
#209 |
.:100%:.
bmw E30>:(
Tiempo: 10.1.1.1.1
el unico problema q me dio el OS4 en el 3g de 8gb es q no conecta a plan de datos alguien tendra la solucion ???
![]() 325i ![]() ![]() Guatemala 25 de mayo de 2010 ![]() ![]() |
#210 |
GuAt
Mercedes Benz '74
#211 |
GuAt
Mercedes Benz '74
Ya esta casi listo el Jailbreak para los 3GS con iboot Nuevo!!!!!!
http://www.actualidadiphone.com/2010...n-iboot-nuevo/ Lo malo es que va a ser un jailbreak tethered, si se apaga, entra en modo de restauracion, |
#212 |
Padawan
Miata M edition
Tiempo: 16.8 slow
Mmmm me espero a un untethered o no? Ese es el dilema
"The NB is a better car, but the NA is a better miata" uuuuuuuhh FUCK ITR'S slowssss laksdjfaksdfjaskdf ![]() ![]() ![]() ![]() |
#213 |
.:100%:.
bmw E30>:(
Tiempo: 10.1.1.1.1
#214 | |
@El_Patatush
yo tenia el mismo clavo y se soluciono bien paja mano cualquier onda mandame pm, pero cobro 2 creditos ![]() |
#215 |
GuAt
Mercedes Benz '74
#216 | |
.:100%:.
bmw E30>:(
Tiempo: 10.1.1.1.1
#217 |
toyota
Ya se puede liberar el ios4 en el 3gs new bootrom
#218 |
toyota
Les dejo el link con mas info parece que hay que esperar a el os 4.1 para que pueda ser compatible http://tecnolatino.com/jailbreak-par...g-3g-en-ios-4/
#219 |
GuAt
Mercedes Benz '74
como sea, ya hay esperanza.... jajajaja
#220 |
toyota
Ya salio el hi8snow
#221 |
GuAt
Mercedes Benz '74
#222 |
Raizen (:
Tiempo: ??????
#223 |
GuAt
Mercedes Benz '74
#224 |
toyota
#225 |
Udyn Fix
6 Mode
Feedback Score: 176 reviews
