ExclamationEste thread fue creado hace 5025 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
Antiguo 07-Dec-2007, 15:53   #1
GuateskateVTi
I WILL UNRICE YOU!!! MOD
Avatar de GuateskateVTi
BMW 330Ci
Tiempo: 10.30
DIFERENCIA ENTRE UN Ek4 y un EK9
Honda Civic VTi-R vs Civic Type R Comparison
Australian VTi-R
Standard Specifications:Model VariantVTi-R Car Series EK4Year1995-1998Doors and Body Style3DR HatchEngine Size1595cc B16A2Fuel SystemMULTI POINT F/INJ Cylinders4 Transmission5MStandard Features15" Alloy Wheels, 4 Speaker Stereo, ABS (Antilock Brakes), Adjustable Steering Col. - Tilt & Reach, Air Conditioning, Airbags - Driver & Passenger (Dual), Central Locking, Engine Immobiliser, Paint - Metallic, Power Door Mirrors, Power Steering, Power Windows, Radio Cassette, Sunroof - Electric and Tilt, Suspension - Sports, Seats - Sport bucket, Centre Console with dual cup holder, Rear seat head restraints, Digital ClockOptional Features
Available ColoursFrost White (NH-538)
Milano Red (R-81)
Dark amethyst pearl (PB-74P)
Vogue silver metallic (NH-583M)
Cypress green pearl (G82P)Bore and Stroke81x87.2mm Power118KW / 160HP @7600rpmTorque148Nm / 15.1kgm @7000rpmWeight to Power Ratio7.71 : 1kg/kW Front BrakesVented Discs, ABSRear BrakesDisc Wheel Dimension 195-55-15
Turning Circle9.8m Compression Ratio10.2 Final Ratio4.4 Tank Capacity45 litres Exterior Length4180mm Exterior Width1695mm Exterior Height1375mm Front Track1475mm Rear Track1475mm Wheel Base2620mm Front SuspensionInd; double wishbones with coil springs gas damper and stabiliser barsRear SuspensionInd; double wishbones with coil springs gas damper and stabiliser barsKerb Weight1105kg Ground Clearance106mm Seating Capacity 4 Exhaust ManifoldCast 4-2-1 style exhaust manifold1/4 Mile time16.2
Civic Type R
Standard Specifications:Model VariantTYPE R Car Series EK9Year1997 - 2001Doors and Body Style3DR HatchEngine Size1595cc B16B Spec RFuel SystemMULTI POINT F/INJ Cylinders4 Transmission5M with LSDStandard Features15" Alloy Wheels, Rear Spoiler, Momo Steering Wheel, RecarosOptional FeaturesCentral Locking, Power Windows, Power Mirrors, Power Steering, Radio Cassette with 4 Speakers, Dual Airbag Package, ABS
CosmeticsLeather wrapped MOMO Steering wheel with SRS airbag, Red Carpet, Red Arm rests, Red Floormats with Type R badging, Titanium gear shifter, Red stiched boot, Carbon centre dash console with Type R badge, Type R Instument cluster, Carbon dash bezel, Emergency Flare, No Coin holder, Red Recaro seats, Bodykit, Red exterior badging, Colour coded exterior panelsBore and Stroke81x87.2mm Power136KW / 185PS @8200rpmTorque16.3kgm @7500rpmWeight to Power Ratio7.37 : 1kg/kW Front BrakesLarger Vented Disc , ABS (optional)Rear BrakesDisc Wheel Dimension 195-55-15 Enkei 5 stud PCD
Turning Circle9.8m Compression Ratio10.8Final Ratio4.4Tank Capacity50litres Exterior Length4185mm Exterior Width1695mm Exterior Height1360mm Front Track1480mm Rear Track1480mm Wheel Base2620mm Front SuspensionInd; double wishbones with coil springs gas damper Rear SuspensionInd; double wishbones with coil springs gas damper and trailing linkKerb Weight1059kg (97 Spec) 1089kg (98 Spec)Ground Clearance105mm Seating Capacity4 Exhaust Manifold4-2-1 style stainless steel exhaust manifold1/4 Mile time15.5
Civic Type R Variations
The legendary EK Civic Type R was first introduced in late 1997. It arrived in the shadows of the already badged Type R of the Integra Type R and the NSX Type R. This EK has been at the forefront of an engineering marvel by producing a whopping 116horsepower per litre of its 1595cc naturally aspirated engine. But enough of the worshipping and lets look at the different types of cosmetic differences found in the EK Civic Type R mould.
August 1997
Civic Type R - Standard version No power options - race trim
Weight 1059kg
September 1998
Civic Type R - Fully optioned version Cosmetic change to front & rear bumpers, Design change in headlight shape, Power Mirrors, Power Windows, Power Steering, Radio Cassette with 4 Speakers (a double din stereo center console was also available), Dual Airbag Package, ABS.
Weight 1089kg
December 1999
Civic Type R - Type Rx All features of the previous version including; Retractable electric door mirrors, Keyless entry unlock system, Aluminum sports pedals. 4 colours were available for sale.
Weight 1099kg
The Type R Comparison
Different pistons are responsible for the compression ratio increases between 160hp & 170hp B16A and the 10.8 ratio for B16B. Readily apparent is the relatively modest change in piston top between B16A 160hp and B16A 170hp for the 10.2 to 10.4 change. However, the radically different piston top for B16B is very clear from the picture. The increase in compression ratio between B16B from B16A is 0.4.
The cut-outs on the piston top to accomodate for valve lift are basically the same between all three piston. This means the B16B camshafts can be installed into both 160ps and 170ps B16A without the need to change to B16B pistons.
On B16B, the inlet ports are manually ported to increase air-flow. The exhaust ports are identical to B16A.B16B intake valve seats are at a different angle to B16A, 45 degrees vs 60 degrees. The intake valves are also different, being lighter and having a thinner valve stem.
On the left are the power curves for B16A 170hp versus B16B. Note the big gain in power after 6000rpm, the VTEC switch-over point between mild and wild cam profiles. The gain at extreme high rpms is readily apparent on the curves. Various individual specifications for B16B can teach us about the feasibility of various modifications to B16A. For eg, the throttle bore diameter for B16B is identical to B16A at 60mm. This means that enlarged throttle bodies for B16A might not be an optimal mod or that a compromise in power delivery might result, eg loss of low-end power in return for gain in high-end power. Note that B16B has identical low and mid range power as B16A.
As with B18C Spec R, the wonder of B16B is the assurance of a 15 to 25hp gain in power on a B16A provided the tuning done by Honda can be completely replicated. Nevertheless even if only a portion can be duplicated, combining with properly designed aftermarket exhaust, headers, and intake could still potentially realize this 15hp gain. B16B engine parts are available from Honda and with care, most of them can be used on B16A for good power gains.
The camshaft profiles (wild cam) change from B16A2 and B16B are :
Cam ProfileB16A2 160psJDM B16A 170psB16B 98RMax Lift (IN/EX)10.4/9.410.7/9.411.5/10.5Open Timing (IN/EX)BTDC 10/BTDC 40BTDC 15/BBDC 40BTDC 18/BBDC 45Close Timing (IN/EX)ABDC 40/ATDC 5ABDC 45/ATDC 7BTDC 45/ATDC 10In order to increase the power output by 15 hp, and the max RPM by 200RPM, the engine goes through many upgrades. It should be noted that the B18C spec.R's cylinder block is used for its endurance.
Ya que no quieren CULOS
EK SQUAD MEMBER No. 123
TIME FOR LUST, TIME FOR LIE
TIME TO KISS YOUR LIFE GOODBYE
SEND ME MONEY, SEND ME GREEN
HEAVEN YOU WILL MEET
MAKE A CONTRIBUTION
AND YOU´LL GET A BETTER SEAT
BOW TO LEPER MESSIAH
GuateskateVTi está desconectado   Responder Citando
Antiguo 07-Dec-2007, 15:56   #2
FIRE
Eurohondero
Avatar de FIRE
Que linda la ek9 full popoito
que triste ser hondero sin honda sdlfjsñlfjlañfljñkljsñklfsjñlsjkñklsjsñksjñkljsñks jñkljñklsjñfsljksf
Antiguo 07-Dec-2007, 16:12   #3
Puro Racing
I ♥ MY CRX
Avatar de Puro Racing
Honda CRX 88
Tiempo: sepaputas
algo cansada la lectura pero ta calidad vaaaaaaaaaaaaaaaaaya pizados para que ya no las confundamos lkajsdlñajdñlajdlkajd
Antiguo 07-Dec-2007, 19:01   #4
GussKiller
hardcore biker
Avatar de GussKiller
nissan datsun bluebird
Tiempo: no he probado
ve uno si aprende aqui, jajaja no tenia ni idea de cual era la diferencia
Hay algun dia seras mia.
GussKiller está desconectado   Responder Citando
Antiguo 07-Dec-2007, 19:51   #5
IsRa_RX
♫♪♫PsychedeliC Only♪♫♪
Avatar de IsRa_RX
Tiempo: 4:20
buena info vos
"Flying is learning how to throw yourself at the ground and miss." - D. A.
IsRa_RX está desconectado   Responder Citando
Antiguo 07-Dec-2007, 19:54   #6
GEORGEJ1
Avatar de GEORGEJ1
q buena info...
GEORGEJ1 está desconectado   Responder Citando
Antiguo 07-Dec-2007, 23:33   #7
BAG
Team AutoSonido
Avatar de BAG
Feedback Score: 107 reviews
buena info, pero un civic con un d16 de 3 puertas del 98 digamos tambien es ek4? o solo el que es vti?
BAG está desconectado   Responder Citando
Antiguo 08-Dec-2007, 09:34   #8
Swiftio VR-4
Avatar de Swiftio VR-4
VITZ RS / KTM EXC 250
Tiempo: 10.75/ 1.42.0
Iniciado por BAG Ver Mensaje
El ciovic de esos años trae D15B en la version japonesa, y es EK3
EK2 es con motor 1300
el q vino de agencia q era 1.6 no vtec no se q motor es jejeje
Toyota Vitz RS 1.5 / Yamaha WR 200
It's more fun to drive a slow car fast than a fast car slow
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
Swiftio VR-4 está desconectado   Responder Citando
Antiguo 08-Dec-2007, 10:13   #9
byestr
Avatar de byestr
[quote=FIRE;1482060;]Que linda la ek9 full popoito
que triste ser hondero sin honda sdlfjsñlfjlañfljñkljsñklfsjñlsjkñklsjsñksjñkljsñks jñkljñklsjñfsljksf[/quot
byestr está desconectado   Responder Citando
Antiguo 11-Dec-2007, 15:24   #10
Vestatito
Que vendrá?
Avatar de Vestatito
nimiel
Tiempo: cabal
la verch... yo quiero uno, cualquiera de los dos... pero quiero uno...
No tengo firma!
Vestatito está desconectado   Responder Citando
Antiguo 13-Dec-2007, 17:22   #11
vistec r
1000WHP 2JZ
Avatar de vistec r
Nice write up
vistec r está desconectado   Responder Citando
Antiguo 19-Dec-2007, 08:52   #12
CoupeVtec
Honda Squad Member
Avatar de CoupeVtec
Honda Civic EX 1995
Tiempo: 10.65
EK9
Visita nuestro foro: http://hondasquadgt.mi-web.es/
CoupeVtec está desconectado   Responder Citando
Antiguo 22-Dec-2007, 14:59   #13
type-R
HALA MADRID!!!
Avatar de type-R
Protegé '99
muy buena indo EK's
type-R está desconectado   Responder Citando
Antiguo 14-Jan-2008, 17:21   #14
bEtOrNiLLo
Avatar de bEtOrNiLLo
QUE BUENA INFO,,, SI QUIERES DESPUES TE PASO LA LISTA COMPLETA DEL LOS MOTORES ..
Swiftio VR-4Quote:
bEtOrNiLLo está desconectado   Responder Citando
Antiguo 21-Jan-2008, 14:22   #15
cristianl
Avatar de cristianl
buenisima la info
cristianl está desconectado   Responder Citando
Antiguo 12-Feb-2008, 11:01   #16
Zapato
Don Zapato ...
Avatar de Zapato
Amelia ♥ Eg6 ♥
Tiempo: Pura Mierda
Feedback Score: 93 reviews
Iniciado por bEtOrNiLLo Ver Mensaje
Swiftio VR-4Quote:
deberias de postearlo aqui ami me interesa !!!!!!!!!!!!!!!!!!!!!
Zapato está desconectado   Responder Citando
Antiguo 15-Mar-2008, 11:44   #17
D16Z6_inside
Avatar de D16Z6_inside
buena informacion alli excelente..
D16Z6_inside está desconectado   Responder Citando
Antiguo 20-Dec-2008, 10:18   #18
Kevo!
Echte Liebe
Avatar de Kevo!
:diablo:
Re: DIFERENCIA ENTRE UN Ek4 y un EK9
osea que una SiR 97 seria ek4 va????
Kevo! está desconectado   Responder Citando
Antiguo 20-Dec-2008, 12:49   #19
spike
el foro ha muerto :(
Avatar de spike
un yaris
Tiempo: don't care
Feedback Score: 52 reviews
buen thread, entiendo q no traduzcás todo eso, pero debiste haber puesto la fuente de dónde lo sacaste...
igual.. buenísima la info
Antiguo 15-Jul-2009, 07:01   #20
k-lin
Avatar de k-lin
buena info, pero nunca entendi porque sticky.. no esque las mire todos los dias, y aunque las viera no es que me vayan a plomazear por no reconocerlas laskdjflaskdjflaksdjfasdf
k-lin está desconectado   Responder Citando
Antiguo 27-Jul-2009, 11:16   #21
el turco
Avatar de el turco
golf gti 1.8turbo a4
Tiempo: 11.13
que buena info man no sabia que diferencias tenian los motores!!!!!!!!!!!!!
el turco está desconectado   Responder Citando
Antiguo 07-Oct-2009, 12:31   #22
oscar sierra
Lowered
Avatar de oscar sierra
vw vento 99
Tiempo: ......!
buena info vos gracias! la vdd ya sabia un par de las diferencias pero no todas!!!
buena onda chavo
oscar sierra está desconectado   Responder Citando
Antiguo 21-Nov-2009, 23:00   #23
Subarulover
Avatar de Subarulover
Iniciado por Swiftio VR-4 Ver Mensaje
ta bueno vos
Subarulover está desconectado   Responder Citando
Antiguo 21-Nov-2009, 23:06   #24
erre
Avatar de erre
FD3S
viejoooooooooooo tu thread pizao ;lksj;las
erre está desconectado   Responder Citando
Antiguo 22-Jan-2010, 06:00   #25
galo1386
Avatar de galo1386
Starlet GT Turbo
Tiempo: ??
Muy interesante el aporte gracias.
Saludos.-
galo1386 está desconectado   Responder Citando
La franja horaria es GMT -6. Ahora son las 18:49.
Page generated in 0,33217 seconds with 11 queries
