Este thread fue creado hace 3049 días. Lo mas probable es que el tema ya se haya resuelto y no necesite más discusión. Aunque si todavía crees que es necesario agregar un comentario, puedes hacerlo.
04-Oct-2015, 12:26 | #1 |
Feedback Score: 85 reviews
[Tarjetas de video GAMERS - Nvidia GTX 650, 750 Ti, 960, 970 AMD 7950, R9 280x, 290!]
VENDIDAS
Articulo: Tarjetas de video -------------------------------------------------------------------------| Modelo/Marca: Nvidia GTX y AMD Radeon -------------------------------------------------------------------------| Especificaciones: ESPECIFICACIONES EVGA Nvidia GTX 970 Edicion SC de 4 GB! ★★ Powered by NVIDIA GeForce GTX 970 GPU ★★ ★★ 1664 CUDA Cores ★★ ★★ 1165 MHz Base Clock ★★ ★★ 1317 MHz Boost Clock ★★ ★★ 121GT/s Texture Fill Rate ★★ ★★ Features PCI-E 3.0 16x, DVI-I, DVI-D, HDMI, DisplayPort★★ ★★ System power supply requirement: 500W★★ GIGABYTE Nvidia GTX 960 Mini-ITX (Mismo rendimiento que una GTX Full Size) ★★ Powered by NVIDIA GeForce GTX 960 GPU ★★ ★★ Integrated with industry's best 2GB GDDR5 memory 128-bit memory interface ★★ ★★ BASE: 1165 MHz / BOOST: 1228 MHz(1190/1253 MHz in OC Mode) ★★ ★★ Features Dual-link DVI-I / Dual-link DVI-D / HDMI / DisplayPort ★★ ★★ System power supply requirement: 400W ★★ MSI Nvidia GTX 960 Special Edition OC y normal ★★ Boost Clock / Base Clock ★★ ★★ 1304 MHz / 1241 MHz (OC Mode) ★★ ★★ 1253 MHz / 1190 MHz (Gaming Mode) ★★ ★★ 1178 MHz / 1127 MHz (Silent Mode) ★★ ★★ 2048 MB GDDR5 / 7010 MHz Memory ★★ ★★ Outputs: ★★ ★★ Dual-link DVI-I x 1 ★★ ★★ HDMI x 1 ★★ ★★ DisplayPort x 3 ★★ GIGABYTE AMD R9 280X ★★ WINDFORCE 3X Cooling system with Triangle Cool technology ★★ ★★ Powered by AMD Radeon™ R9 280X GPU ★★ ★★ Integrated with 3GB GDDR5 memory, 384-bit memory interface ★★ ★★ Features DVI-I / HDMI / mini DisplayPort*2 ★★ ★★ BASE:1000MHz / BOOST:1100 MHz ★★ ★★ System power supply requirement: 600W ★★ GIGABYTE AMD R9 290 ★★ WINDFORCE 3X 450W cooling system ★★ ★★ Powered by AMD Radeon™ R9 290 GPU ★★ ★★ Integrated with 4GB GDDR5 memory, 512-bit memory interface ★★ ★★ Features DVI-D*2 / HDMI / DisplayPort ★★ ★★ Core Clock: 1040 MHz ★★ ★★ System power supply requirement: 600W ★★ Negocio: Compra / Venta / Cambio / Subasta -------------------------------------------------------------------------| Tiempo de uso: GIGABYTE GTX 960 - NUEVA MSI GTX 960 Special Edition Green OC (La verde) - USADA COMO NUEVA VENDIDA MSI GTX 960 Special Edition White (La blanca) - USADA COMO NUEVA GIGABYTE AMD R9 290 - NUEVA GIGABYTE AMD R9 280x - USADA COMO NUEVA -------------------------------------------------------------------------| Tiempo ofrecido de Garantia: 3 meses. -------------------------------------------------------------------------| Tiempo de entrega y forma de pago: Pago contra entrega o bien deposito previo y se envia por GUATEX (Ver mis Itraders) -------------------------------------------------------------------------| Precio: GIGABYTE GTX 960 - Q 1700.00 MSI GTX 960 Special Edition White (La blanca) - Q 1800.00 MSI GTX 960 Special Edition Green OC (La verde) - Q 1900.00 VENDIDA GIGABYTE AMD R9 280x - Q 2000.00 GIGABYTE AMD R9 290 - Q 2400.00 -------------------------------------------------------------------------| Negociable? Si se lleva 2 o mas, sip. -------------------------------------------------------------------------| Estado general especificar en base a lo detallado a continuación: 4 pts: Usado como nuevo y algunas NUEVAS. QUE INCLUYO: Todo lo que se incluye en las fotos. Todas las tarjetas de vídeo cuentan con 3 meses de garantía por si llegara a presentarse cualquier desperfecto de fabrica. Las dos tarjetas MSI GTX 960 y EVGA GTX 970 no cuentan con caja o accesorios, pero de igual forma tienen 3 meses de garantia. Cualquier duda sobre benchmarks o rendimiento en cuanto a juegos, solo envien PM y respondere todas sus dudas -------------------------------------------------------------------------| Teléfono de Contacto con el Vendedor (OBLIGATORIO) : 55757685 ( llamada o Whatsapp) o por PM -------------------------------------------------------------------------- FOTOS: Última edición por Maick; 18-Oct-2015 a las 14:16 |
04-Oct-2015, 19:17 | #2 |
Respuesta: [Tarjetas de video GAMERS - Nvidia GTX 650, 750 Ti, 960, 970 AMD 7950, R9
04-Oct-2015, 19:18 | #3 |
Feedback Score: 115 reviews
esperando las 750 ti :clavito:
sadsadfsdgffdghgdhfjjgkknljñljkñlñ..... |
04-Oct-2015, 21:12 | #4 |
Belic Member
Feedback Score: 113 reviews
y la 970?
04-Oct-2015, 21:22 | #5 |
05-Oct-2015, 07:06 | #6 |
06-Oct-2015, 09:07 | #7 |
06-Oct-2015, 18:35 | #8 |
06-Oct-2015, 19:05 | #9 |
entonces la gtx 750 para cuando?
06-Oct-2015, 19:11 | #10 |
07-Oct-2015, 07:35 | #11 |
07-Oct-2015, 11:35 | #12 |
Cuando tendras una gtx 970 y r9 390?
07-Oct-2015, 13:22 | #13 |
Que tal,
La GTX 970 ya la tengo el dia de mañana en la noche. La R9 390 creo que no voy a traer. Solamente la R9 290 que tengo ya publicada La ultima que voy a traer, pero ya la otra semana va a ser una Nvidia GTX 780 Ti Special edition, que tiene un mayor rendimiento que una Nvidia GTX Titan e incluso mayor que una Nvidia GTX 980 de ultima generacion :o Saludos y quedo al pendiente de cualquier duda |
07-Oct-2015, 17:50 | #14 |
08-Oct-2015, 08:23 | #15 |
08-Oct-2015, 11:31 | #16 |
me interesa una gtx 650 o la 750 TI, cuanto las publicas?
08-Oct-2015, 12:18 | #17 |
por si te entran las 750ti o la 650 me mandas pm porfa
08-Oct-2015, 13:50 | #18 |
08-Oct-2015, 13:54 | #19 |
The Chosen One
Feedback Score: 132 reviews
Como tenés más de 5 artículos... Tenés que abrir un thread en negocios y servicios...
08-Oct-2015, 14:04 | #20 |
10-Oct-2015, 08:38 | #21 |
Buenas yo compre la GTX 970 que vendía Maick. y tuve problema con mi Bios, tenia que actualizarlo, al principio pensé que no funcionaba bien mi fuente con la tarjeta y le escribí a Maick, su respuesta fue de inmediata, me dio soluciones, me propuso cambiarme la tarjeta por otra, bueno para hacerlo mas corto Excelente la atención que da y se nota la responsabilidad, al final actualice mi bios y funciona la tarjeta, pero quiero destacar la confianza que da Maick, así que recomendado 100 % para aquel que dude puede comprar tranquilo.
10-Oct-2015, 08:41 | #22 | |
10-Oct-2015, 10:29 | #23 |
11-Oct-2015, 15:30 | #24 |
Que tal,
Fijate que aun no ha venido. Vendra esta semana al parecer, para mientras publique otras de gama media en este otro tema: http://www.velocidadmaxima.com/forum...d.php?t=515652 Saludos |
11-Oct-2015, 17:23 | #25 |
ya se vendio la EVA GTX 970?
amd, gamer, nvidia, radeon, tarjeta |
